whatisgoingon
Jul 26, 2018Aspirant
CM700/Nighthawk Dropping Internet + DoS/WLAN access rejected spam
All of these problems began showing in the logs a few minutes after updating to V1.2.0.24_1.0.1. My internet has been disconnecting multiple times a day (modem loses connection).
In the logs I...
DarrenM
Jul 30, 2018Sr. NETGEAR Moderator
Not in the router logs but the logs of the modem do you seen any T3 or T4 timeouts?
DarrenM
whatisgoingon
Jul 30, 2018Aspirant
I never knew I could login to the modem like this so I'm a bit unfamiliar with the data. Unfortunately, I recently rebooted the modem to regain internet connection which seems to have cleared the logs. I do see:
No Ranging Response received - T3 time-out
MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Downstream
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | UnCorrectables |
| 1 | Locked | QAM 256 | 17 | 603000000 Hz | -7.7 dBmV | 37.3 dB | 0 | 0 |
| 2 | Locked | QAM 256 | 18 | 609000000 Hz | -7.7 dBmV | 37.3 dB | 0 | 0 |
| 3 | Locked | QAM 256 | 19 | 615000000 Hz | -7.2 dBmV | 37.3 dB | 0 | 0 |
| 4 | Locked | QAM 256 | 20 | 621000000 Hz | -7.4 dBmV | 37.3 dB | 0 | 0 |
| 5 | Locked | QAM 256 | 21 | 627000000 Hz | -8.0 dBmV | 37.3 dB | 0 | 0 |
| 6 | Locked | QAM 256 | 22 | 633000000 Hz | -8.2 dBmV | 36.6 dB | 7 | 0 |
| 7 | Locked | QAM 256 | 23 | 639000000 Hz | -7.7 dBmV | 37.6 dB | 7 | 0 |
| 8 | Locked | QAM 256 | 24 | 645000000 Hz | -8.2 dBmV | 37.3 dB | 0 | 0 |
| 9 | Locked | QAM 256 | 25 | 651000000 Hz | -8.2 dBmV | 37.3 dB | 0 | 0 |
| 10 | Locked | QAM 256 | 26 | 657000000 Hz | -8.2 dBmV | 36.6 dB | 0 | 0 |
| 11 | Locked | QAM 256 | 27 | 663000000 Hz | -8.2 dBmV | 37.3 dB | 0 | 0 |
| 12 | Locked | QAM 256 | 28 | 669000000 Hz | -7.7 dBmV | 37.3 dB | 0 | 0 |
| 13 | Locked | QAM 256 | 29 | 675000000 Hz | -7.2 dBmV | 37.3 dB | 0 | 0 |
| 14 | Locked | QAM 256 | 30 | 681000000 Hz | -7.2 dBmV | 37.6 dB | 0 | 0 |
| 15 | Locked | QAM 256 | 31 | 687000000 Hz | -7.2 dBmV | 37.3 dB | 0 | 0 |
| 16 | Locked | QAM 256 | 32 | 693000000 Hz | -7.2 dBmV | 37.3 dB | 6 | 0 |
| 17 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 18 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 19 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 20 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 21 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 22 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 23 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 24 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 25 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 26 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 27 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 28 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 29 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 30 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 31 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 32 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
Upstream
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
| 1 | Locked | ATDMA | 2 | 5120 Ksym/sec | 30100000 Hz | 54.5 dBmV |
| 2 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 3 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 4 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 5 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 6 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 7 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 8 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
54.5 dBmV seems very high compared to the downstream values or is that normal?
Thanks for the help.
- whatisgoingonJul 31, 2018Aspirant
Just experienced another drop in internet. Before it would fix itself but now it seems I need to do a full restart to get the internet working. I was able to grab the log before restarting.
Modem Logs:
Jul 31 2018 07:08:17 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:08:17 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:08:46 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:08:47 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:09:31 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:09:31 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:10:04 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:10:04 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:10:45 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:10:45 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:11:17 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:11:17 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:11:47 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:11:47 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:12:23 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:12:24 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:12:55 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:12:56 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:13:40 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:13:40 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:14:20 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:14:20 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:15:02 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:15:02 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:15:42 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:15:42 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:16:11 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:16:12 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:17:04 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:17:05 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:17:36 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:17:36 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:18:28 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:18:28 Critical (3) No Ranging Response received - T3 time-outAnd here are some of the router logs. The logs were empty up until July 20th when I upgraded to the latest firmware, except for one event in May. Not sure if this is a coincidence or not. This is from the same time as the modem log (router time is behind 3 hours). Note that this is how the logs look even when I'm not having issues. The other day it seemed to be allowing access to my phone every 5 minutes.
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:31:49
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:30:34
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:29:17
[Internet connected] IP address: xxx.xxx.xxx.xx Tuesday, July 31,2018 04:28:47
[Internet disconnected] Tuesday, July 31,2018 04:28:04
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:28:02
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:26:35
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:25:19
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:23:58
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:22:41
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:21:09
[Internet connected] IP address: xxx.xxx.xxx.xx Tuesday, July 31,2018 04:20:09
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:19:52
[Internet disconnected] Tuesday, July 31,2018 04:19:02
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:18:35
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:17:14
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:15:57
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:14:41
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:13:22
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:12:05
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:10:49
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:09:25
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:08:07
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:06:50
- DarrenMJul 31, 2018Sr. NETGEAR Moderator
Yes you have alot of timeouts this is typically a connection issue with the ISP something could of happened to the lines or the cable box out in your neighborhood you will want to have a ISP tech come check the levels and maybe investigate your area.
DarrenM
