win10arg
May 02, 2019Aspirant
CM700/R7000 combo slower speeds then with spectrum modem/R7000
purchased new CM700 to replace old rented spectrum ARRIS DG1670, nothing was changed on ISP end (called and checked) nothing has been moved just a switch out. 2.4 in the house is getting what it was ...
May 02, 2019Guru - Experienced User
After changing modems, did you reset the R7000? its always a good idea to reset whenever you're changing out equipment. it'll cause the least errors and problems. other question is did you test the speeds over ethernet connection? Wifi speeds can change/be variable based upon environment. it could have been someone else added something in your area around the same time to create interference.
