win10arg
May 02, 2019Aspirant
CM700/R7000 combo slower speeds then with spectrum modem/R7000
purchased new CM700 to replace old rented spectrum ARRIS DG1670, nothing was changed on ISP end (called and checked) nothing has been moved just a switch out. 2.4 in the house is getting what it was ...
win10arg
yes the main computer wired in gets greet speeds 250-275mps, eveything else in the house (blu-ray players, roku's, 3ds etc) all are getting the speeds they did, the NEW 4K tv, my phone and my pc are the only things on the 5G network. YES i reset R7000 router back to factory when installing new modem. wired in is good, 2.4 is good 5G i'm getting 50-55mps when I use to get 150-175mps.
May 02, 2019Guru - Experienced User
Is FW up to date? I've heard others report having some issues with FW versions on the R7000. Might check the NightHawk forums for users having issues with the R7000 and wifi speeds on 5Ghz. If your getting to spec speeds on wired and 2.4Ghz, then your modem is fine. The R7000 needs to be looked at.
Might give Voxels 3rd party FW a try as well.
- win10argMay 07, 2019Aspirant
yeah went thru that site, not trying to get into flashing software onto another device...just want help configuring these 2 netgear machines to at least give me the speeds I had with the 5yr old spectrum modem.
