RWL's avatar
RWL
Follower
Nov 04, 2015
CMD31T Thru Put
Modem speed drops to < 1 Mbps DL, UL < 100 Kbps.  Cox Cable.  Have had zero problems with them.  Yesterday, Cox had me power down, disco coax, wait thirty seconds and brought back up.  DL speed was again > 50 Mbps and upload was > 2 Mbps.  Same thing happened today.  Modem has 4 more days of warranty.  Any ideas?  Modem is not hot but is warm to the touch.  No smells like in some of the other chains on this modem.
  • Hello RWL
    The other thing I would try is swap out the Ethernet and cable line to see if its a bad cable but if its still acting like that I would contact netgear phone support in case its faulty while its still under warranty.
    DarrenM
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello RWL
    DarrenM
