CF141's avatar
CF141
Follower
Jan 04, 2016
CMD31T: Unable to logon
I have had this device for some time now (over 6 months) and I have had 2 routers connected to the modem through a basic network switch.  I just canceled my TV portion of my cable service the other day and while I was talking to the rep my phone (and entire internet connection) blipped out for a second then seemed to come back.  I found after this that only one of the routers could obtain an IP address at a time, the modem was only serving up one IP address.  I called the support at the ISP (TWC) and they said that it sounded like the modem had entered something called "Bridge Mode" and that I had to disable this feature on my modem.  So I tried to log onto my CMD31T and forgot the password that I had changed it to, nothing seemed to work.  I then tried the "Factory defaults restore" to put the default password back on, however the default password still does not work.  Does this mean my modem is shot? Or am I missing something?
Thanks
  • I am having what appears to be the same issue. Performed a factory reset and the modem does not accept the default passwords.
    • DarrenM's avatar
      DarrenM
      Sr. NETGEAR Moderator
      Hello CF141
      What routers are you using it sounds like it could be a conflict in one of the routers settings why not just remove the switch and then connect the routers and have one of them as just a AP.
      DarrenM
