lxwidm
Jun 16, 2022Aspirant
Coax cable can't screw-in to modem/router.
I tried to screw-in a standard coax cable into my modem/router but it doesn't screw-in. Is there a special coax cable required for netgear?
Jun 17, 2022Guru - Experienced User
Take a look at the end of the coax. I've seen them snipped off and the copper wire get flattened a bit. Not a lot but just enough to cause issues when pushing into the connector.
Got a picture of the end of the coax cable?
- lxwidmJun 17, 2022Aspirant
The problem is the threads don't match. The female connector in the cable modem/router seems to be thinner than the standard one. I am able to screw the coax cable into all the other devices except this one. Does this require a special coax cable?
- plemansJun 17, 2022Guru - Experienced User
No its standard rg-6. Do you have a photo of both?
