Balassit
Aug 02, 2019Aspirant
Coaxial cable connect to modem
I am trying to insert the coaxial cable into my modem, but it will not screw on. The modem has a flat top on the cable input which seems to be an issue. I can connect the other end to the wall outlet....
vkdelta
Aug 08, 2019NETGEAR Employee Retired
Please provide a picture. It is hard to know the issue without it.
MichelleM123
Sep 21, 2019Aspirant
Same problem here. Coaxial cable connection is flat on the top and will not screw.
- antinodeSep 22, 2019Guru
> Same problem here. [...]
How can you tell?
> [...] Coaxial cable connection is flat on the top and will not screw.
> Otherwise, a picture might be more helpful than your description.> Please provide a picture. It is hard to know the issue without it.
It's a consensus. Without being able to see the thing, these
descriptions are inadequate.
