kortina
Jun 25, 2022Aspirant
Combine AX6000 WiFi Cable Modem Router (CAX80) with (WAX630) Access Points mesh?
I have a mesh of (WAX630) Access Points, and I was thinking about replacing my modem with an AX6000. I see this modem also has wifi and routing, and I'm wondering if it is possible to configure the W...
Jun 25, 2022Guru - Experienced User
The CAX80 works as a main host router and wifi. Doesn't have any MESH support abilities. You'll need to check with your WAX devices to see if they support any kind of extender modes. If they do then they could connecte to the CAX80 wifi. Or use them in AP mode and ether disable the wifi on the CAX80 or you could have two separate wifi SSID names.
