Anonymous
Jun 04, 2021Comcast - Not Compatible Any Longer?/Firmware Update
Appears that the C7800 Netgear cable modem is no longer compatilble with Xfinity. It shows on my account that "filters not compatible." This correct? Also, my Netgear app is stating firmware not c...
Jun 04, 2021Guru - Experienced User
ISP's are great at messing up the firmware information. the firmware is sent when they provision the modem. So rarely does it get updated because anytime its updated, the ISP has to recertify it which costs them $. so we rarely see combo devices get updated.
You can check what version the isp should be on (not always correct either)
Anonymous
Jun 04, 2021Great info!! Any WiFi standalone router you would recommend for 3000 sq.ft. home?
Thanks!
Thanks!
- plemansJun 05, 2021Guru - Experienced User
when you start getting above that 2200-2500sqft, I usually start steering people to mesh systems.
they don't have the peak speed of the flagship routers but do tend to have higher consistent speeds throughout the home.
And I'm a fan of the triband mesh systems and not dual band.
If you're looking for single router soluctions, the R7800 is what I'd recommend for the AC routers.
In terms of AX, I'm a bit torn as I've only used a few so not sure what I'd actually recommend in terms of stability/rock solid device.
