SparroHawc
Nov 08, 2016Aspirant
Comcast and DNS hijacking - how to narrow it down?
I can't get through to the DNS server I want to for love or money. If I set my DNS server address to 1.2.3.4 (not a DNS server), I still get results. If I get the Source of Authority for a given...
DarrenM
Nov 11, 2016Sr. NETGEAR Moderator
Hello SparroHawc
What the Netgear rep has told you is right I am guessing it has to do with the DNS servers that comcast is pushing down to you but it would be hard to get a hold of someone high enough at comcast to answer that question for you.
DarrenM
- SparroHawcNov 15, 2016AspirantIf I switch the device to bridge mode, would that prevent it from doing any packet modification if it -is- the router that's causing the issue? Can I hook a computer up with an ethernet cable to the device while it's in bridge mode and still be able to hit the internet?
- DarrenMNov 17, 2016Sr. NETGEAR Moderator
Hello Sparrowhawc
Yes you can but it would be like hooking a PC up to a cable modem directly without a routers protection.
DarrenM
