Ghoulardi57
May 15, 2021Aspirant
Comcast and Speed
Just upgraded to 200 from 100mbps with Xfinity. I am still getting speeds from previous service, about 92mbps. Restarted my C3700v2 many times and Comcast is so far no help. They insinuated I migg...
May 15, 2021Guru - Experienced User
Are you speed testing with a wired or wireless device? Wired is preferred.
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
The 3700 modem is capable of 200Mpbs...
- Ghoulardi57May 15, 2021Aspirant
Wreless and have done all this.
Here are some scrennshots as I wasn't sure exactly what you needed.
- FURRYe38May 15, 2021Guru - Experienced User
Please use the Choose File button when you post to attach your capture files. Sometimes it takes longer using the inline as a forum moderator needs to approve the pictures.
- plemansMay 16, 2021Guru - Experienced User
A couple things.
1. your power levels are pretty high. You want between -7.5dbmv and +7.5dbmv. you're 12+. a bit hot. A attenuator a even a 3x splitter could maybe help.
2. are you testing wired? or wireless? the c3700 isn't the highest performing combo device.
3. your wired speeds. if you're testing wired. are you connecting at gigabit speeds? you're results are implying on 10/100mbps speeds.
You can view them here:
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
Attached again as requested
