FAUguy's avatar
FAUguy
Comcast bricked my CM2050v
I have a Netgear CM2050v that I have been using since November 2021 without any problem. Occasionally Comcast will have a service outage, due to an issue or saying there is "planned maintenance". Tod...
  • FURRYe38's avatar
    Glad the replacement worked.
    Ya, It will be up to the ISP to support model modems on there mid split or higher speed tiers. All up them.
    Probably not. I'll check and see if I can find out what happened.
    Please mark your thread as solved so others will know.
    Enjoy.
