FAUguy
Feb 10, 2025Aspirant
Comcast bricked my CM2050v
I have a Netgear CM2050v that I have been using since November 2021 without any problem. Occasionally Comcast will have a service outage, due to an issue or saying there is "planned maintenance". Tod...
- Mar 06, 2025
Glad the replacement worked.
Ya, It will be up to the ISP to support model modems on there mid split or higher speed tiers. All up them.
Probably not. I'll check and see if I can find out what happened.
Please mark your thread as solved so others will know.
Enjoy.
Mar 06, 2025Guru - Experienced User
Any updates on this?
FAUguy wrote:
I have a Netgear CM2050v that I have been using since November 2021 without any problem. Occasionally Comcast will have a service outage, due to an issue or saying there is "planned maintenance". Today I got a message saying services may interrupt due to a service upgrade. About 10:30am all our service (Cable TV, Internet and Voice) went out for about 40 minutes. After the cable TV came back on, I checked the CM2050v and the MultiGig light was flashing very fast (no other lights on). I pulled the power for a few minutes and as soon as I plug the power back in, the power LED flashes red 1 time very quick, and then the MultiGig light starts flashing fast again. Tried the Reset button and isn't rebooting it (like it use to). I've never had this problem before. I had to reconnect my older Arris TM822G eMTA modem and use the Xfinity app to get it added on my account, and it's working fine (but at 1/5th the speed).
So in my opinion, it appears that whatever Comcast did in the area fried my modem. Could it of been a downstream voltage surge in the line or something else. But now I'm going to have to spend $360 for a new CM2050V (as it was $240 in 2021 when I originally bought it).
FAUguy
Mar 06, 2025Aspirant
I've been using the replacement CM2050v for the past few weeks without any problem.
Today the modem rebooted a couple times, and when I logged into the Admin page it shows there was a firmware update to V10.01.03. I looked on the Cable Diagnostic screen, and it looks a little different (like the v9 from a few years ago) and now have 1 OFDM Upload channel.
I did a Speed test, and before on the 1Gb plan I would get about 1180Mbps down and 24 up, now I'm getting 1288 down and 45 up. So maybe they are doing this mid-split work in the area as well. Technically the C2050v says it can do a few hundred mbos upload with 2 OFDM D3.1, but Comcast site says that for mid-split they only support the CM2500 and CM3000 (which doesn't come with eMTA voice).
The bad one that I sent back to Netgear, is there a year to know if they are going to test it and what the results were?
