FAUguy
Feb 10, 2025Aspirant
Comcast bricked my CM2050v
I have a Netgear CM2050v that I have been using since November 2021 without any problem. Occasionally Comcast will have a service outage, due to an issue or saying there is "planned maintenance". Tod...
- Mar 06, 2025
Glad the replacement worked.
Ya, It will be up to the ISP to support model modems on there mid split or higher speed tiers. All up them.
Probably not. I'll check and see if I can find out what happened.
Please mark your thread as solved so others will know.
Enjoy.
Kitsap
Mar 10, 2025Master
FAUguy wrote:I've been using the replacement CM2050v for the past few weeks without any problem.
Today the modem rebooted a couple times, and when I logged into the Admin page it shows there was a firmware update to V10.01.03. I looked on the Cable Diagnostic screen, and it looks a little different (like the v9 from a few years ago) and now have 1 OFDM Upload channel.
I did a Speed test, and before on the 1Gb plan I would get about 1180Mbps down and 24 up, now I'm getting 1288 down and 45 up. So maybe they are doing this mid-split work in the area as well. Technically the C2050v says it can do a few hundred mbos upload with 2 OFDM D3.1, but Comcast site says that for mid-split they only support the CM2500 and CM3000 (which doesn't come with eMTA voice).
If you are on a current Xfinity plan, not a legacy plan, your upstream throughput should be at least 100 Mbps. The fact you have 45 indicates a problem or possibly you have not been upgraded to mid-split. At this time there are many reports of CM2050V owners seeing the upgraded firmware, V10.01.03, yet there are no reports of anyone seeing upload tests over 45.
If you see any upstream throughput test values at 100 or above, please make a new post here on the forum and report it.
FAUguy
Mar 10, 2025Aspirant
I am on a Comcast grandfathered plan from about 5-6 years ago. It is Extreme Pro Internet, which is what they use to call it before changing the name to Gigabit. I've always got about 1100 down and 25 up. Now with the new v10 firmware the download is 1288 and up is 45.
- KitsapMar 10, 2025Master
FAUguy wrote:I am on a Comcast grandfathered plan from about 5-6 years ago. It is Extreme Pro Internet, which is what they use to call it before changing the name to Gigabit. I've always got about 1100 down and 25 up. Now with the new v10 firmware the download is 1288 and up is 45.
Thanks. I am on a similar legacy plan.
