FAUguy
Feb 10, 2025Aspirant
Comcast bricked my CM2050v
I have a Netgear CM2050v that I have been using since November 2021 without any problem. Occasionally Comcast will have a service outage, due to an issue or saying there is "planned maintenance". Tod...
- Mar 06, 2025
Glad the replacement worked.
Ya, It will be up to the ISP to support model modems on there mid split or higher speed tiers. All up them.
Probably not. I'll check and see if I can find out what happened.
Please mark your thread as solved so others will know.
Enjoy.
FAUguy
Mar 10, 2025Aspirant
I am on a Comcast grandfathered plan from about 5-6 years ago. It is Extreme Pro Internet, which is what they use to call it before changing the name to Gigabit. I've always got about 1100 down and 25 up. Now with the new v10 firmware the download is 1288 and up is 45.
Kitsap
Mar 10, 2025Master
FAUguy wrote:I am on a Comcast grandfathered plan from about 5-6 years ago. It is Extreme Pro Internet, which is what they use to call it before changing the name to Gigabit. I've always got about 1100 down and 25 up. Now with the new v10 firmware the download is 1288 and up is 45.
Thanks. I am on a similar legacy plan.
