MMerhar
Nov 03, 2020Aspirant
Comcast C7100V hanging/crashing
Yesterday morning I discovered my C7100V cable modem router was hung: no lights flashing, all connections failing with "no connection possible to that service." Rebooted and discovered that this si...
Nov 03, 2020Guru - Experienced User
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
- MMerharNov 03, 2020Aspirant
As this installation contains both a CATV DVR and a Cable Internet Router, there is of necessity exactly one Coax splitter. All wiring is high quality unspliced RG-6/U, and as I said Comcast reports good signal levels up/down when the unit is working.
Both 2.4 GHz and 5 GHz radios are on fixed channel assignments. The key elements associated with failure are at least one Guest AP enabled (i.e. on 2.4 GHz) and/or an active login to the "NETGEAR Web-based Gateway Configuration Utility" a.k.a. web admin console, via Ethernet or WiFi.
