MMerhar
Nov 03, 2020Aspirant
Comcast C7100V hanging/crashing
Yesterday morning I discovered my C7100V cable modem router was hung: no lights flashing, all connections failing with "no connection possible to that service." Rebooted and discovered that this si...
Nov 05, 2020Guru - Experienced User
Ok, thanks for letting us know. Sounds like a faulty modem.
Enjoy. :smileywink:
MMerhar
Nov 05, 2020Aspirant
FURRYe38 wrote:Ok, thanks for letting us know. Sounds like a faulty modem.
Enjoy. :smileywink:
"Faulty", as in "acted identically to a new-in-box unit of the same model number, running the same software version."
So, in my humble opinion, if you believe that to be the case then the actual fault stems from a common element, as two possible examples the software version it's running, or the architectural specs of the product itself that allows the whole thing to go unresponsive if some interface gets into an unexpected state.
- FURRYe38Nov 05, 2020Guru - Experienced User
Well something that NG support and pass to engineering to take a look at.
Something to let them know about.
