ChuckC3
Oct 30, 2021Aspirant
Comcast Compatibility - Configuration Questions
I have a new AX2700 Cable Modem/Router that I have had for less than a month that I purchased to replace an equivalent Comcast product that I was renting. Everything in my network works fine excep...
Oct 30, 2021Guru - Experienced User
What happens if you go in to the CAX modems web page and setup some IP addresses for each of these devices under Advanced Tab/Settings/LAN Setup?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 or 149 to 161 channel on 5Ghz.
ChuckC3
Oct 31, 2021Aspirant
Thanks, that's a little advanced for me to setup channels. I'd rather not get into that. I have just used the default settings for that.
- FURRYe38Oct 31, 2021Guru - Experienced User
Sometimes channels may need to be changed if there are wifi nieghbors near by.
If you need help with this, please find a near by friend, family member or a neighbor that can help you out.
Good luck.
