ChuckC3
Oct 30, 2021Aspirant
Comcast Compatibility - Configuration Questions
I have a new AX2700 Cable Modem/Router that I have had for less than a month that I purchased to replace an equivalent Comcast product that I was renting. Everything in my network works fine excep...
ChuckC3
Oct 31, 2021Aspirant
Thanks, that's a little advanced for me to setup channels. I'd rather not get into that. I have just used the default settings for that.
Oct 31, 2021Guru - Experienced User
Sometimes channels may need to be changed if there are wifi nieghbors near by.
If you need help with this, please find a near by friend, family member or a neighbor that can help you out.
Good luck.
- ChuckC3Oct 31, 2021Aspirant
Thanks, I don't think I have that problem...I only want to do what I need to do to be 100% compatible with Comcast.
- FURRYe38Oct 31, 2021Guru - Experienced User
Contact the ISP and talk to them about it and getting any modem you buy connected to there network.
Good Luck.
I've tried that. Unfortunately, they (Comcast) will point the finger back at Netgear. I really think that if Netgear advertises that their Cable Modem/Routers are completely compatible with Comcast, Netgear needs to do more to tell us what configuration settings are needed to work with Comcast. We should be able to unplug the Comcast modem/router and plug in the Netgear equivalent and it should just work exactly like the Comcast box did.
