Retired_Member
Jan 27, 2018Comcast problem or C7500-100NAS problem?
Model: Netgear C7500-100NAS Firmware version V1.01.32 Hello all, I am having an issue with bad Internet connection from Comcast and they suggested that it was my brand new C7500's fault which d...
- Feb 02, 2018
I suggest contacting your ISP and have them send a Tech to check your home connections and the connections in the area.
DarrenM
Retired_Member
Feb 01, 2018Yes, I am getting some T3 timeout errors:
MDD message timeout;CM-MAC=08:02:8e:**:**:**;CMTS-MAC=00:01:5c:**:**:**;CM-QOS=1.1;CM-VER=3.0;
No Ranging Response received - T3 time-out;CM-MAC=08:02:8e:**:**:**;CMTS-MAC=00:01:5c:**:**:**;CM-QOS=1.0;CM-VER=3.0;
DarrenM
Feb 02, 2018Sr. NETGEAR Moderator
DarrenM
- Retired_MemberFeb 13, 2018
Looks like it was a Comcast problem after all. After getting a tech out they finally agreed that the problem was on their end. Thank you for your help!
- tomgruFeb 25, 2018Tutor
Seeing same.... have tech coming tomorrow. Curious... what area are you in? i'm in Seattle (Redmond) area.
- Retired_MemberMar 02, 2018
Ended up having a tech out to our place, they found that there was noise on the line from another unit in our appartment building. We are in DC. Hope you got your issue sorted out!
