Jodyjay
Jan 09, 2024Aspirant
Comcast Router Recommendations
I currently have a Motorola MB8600 modem, and an Orbi mesh router system (RBR750 router and two RBS750 satellites). The MB8600 is a DOCSIS 3.1 modem with a 1 gbps port. I believe my internet plan w...
- Jan 09, 2024
Yes.
Jodyjay
The MB8600 is still on Comcast's list of compatible modems. https://www.xfinity.com/support/devices/#auth
Jan 09, 2024Guru - Experienced User
It should be good up to 800Mpbs on there speed tier package. Just keep the modem for now and the Orbi system you have. You'll be fine.
