Royalh13's avatar
Jan 27, 2018
Comcast/Xfinity Says Hardware problem with CM1000 - Offshore Netgear support says "No Problem"
Netgear Existing Case # 29644403 (via phone call)   Summary: Comcast/Xfinity technician says there's an issue with my CM1000 because of high TX power levels (see screenshots). However Netgear's of...
  • DarrenM's avatar
    DarrenM
    Feb 01, 2018
    It is a possibility of a hardware issue but  comparing it to the cable box may not be a great way to know or not since the cable box is less sensitive with the signal levels for it to work compared to a modem. But if you believe that the tech has done everything he can to fix the signal then you may want to work with Netgear support and get a RMA.
    DarrenM
