Publisher_Inter
Apr 06, 2021Aspirant
compatability with viasat isp
Hello, My isp is a company called VIASAT out of Carlsbad, Ca. The viasat modem is junk. I cannot get a straight answer from Viasat ISP as to whether the Netgear coax cable, can replace the Viasa...
Apr 06, 2021Guru - Experienced User
Cable modems or Coax modems are only meant for cable modem ISPs. SAT ISPs usually use different modems for there services. Usually specific modems or gatways that are tied to there systems. The ISP should and do have this information on what they use and what IS required for there services.
