Timpanist-1
Feb 26, 2021Aspirant
Compatibility of Netgear CM2000 with Ooma voice telephone service
Hello Netgear Users ---- I purchased but have not yet connected a new Netgear Nighthawk CM2000 2.5 Gpps internet speed cable modem. I've had problems getting good voice reception on my internet ...
Feb 26, 2021Guru - Experienced User
What router is it going through?
What is your current modem?
What speeds do you pay for?
What speeds do you actually get?
In my experience, voip devices tend to not need a whole lot of bandwidth. It tends to either be a router issue or the ooma service that has issues. It isn't usually a modem issue and if it is a modem issue, its not isolated to voip devices.
Timpanist-1
Mar 04, 2021Aspirant
Thanks for your reply! The Router is a Netgear Nighthawk R7000. Speedtest comes back at Download 60 mbps, Upload 30 mbps and the number of Pings varies, sometimes as low as 10, sometimes as high as 90. I wonder if these numbers will vary much depending on local traffic on the Wi-Fi or the local neighborhood? Ooma suspects the Router is the issue, but this Router is just around 4 years old.
