6gkids
Oct 04, 2015Aspirant
Computer cannot detect wireless cable gateway cg3000d
I have cox network with a Cg3000d wireless cable gateway, 2 in one. I have it wired and use it for wireless as well. My map shows my pc going to switch to modem to gateway to network. REALLY? I did...
- Oct 11, 2015
That listing all looks perfectly normal to me, the PC is allocated an IP address by the router, in this case 192.168.0.5, note not 162.198.0.5 as per your post 3 which I assume was a typo?
DHCP is not guaranteed to allocate the same IP address each time to the same computer / device, especially if you have factory reset the router as you said you did in post 3.
So basically I see no issues with your router connection, and the only outstanding question is the network map. If you still have issues there could you please post a screen grab?
6gkids
Oct 11, 2015Aspirant
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Windows\system32>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Broadcom NetLink (TM) Gigabit Ethernet:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Broadcom NetLink (TM) Gigabit Ethernet
Physical Address. . . . . . . . . : D0-67-E5-06-4A-D0
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 192.168.0.5(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Sunday, October 11, 2015 6:13:24 AM
Lease Expires . . . . . . . . . . : Sunday, October 11, 2015 12:52:34 PM
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DNS Servers . . . . . . . . . . . : 68.105.28.11
68.105.29.11
68.105.28.12
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.{92542916-2D59-4FFD-99AF-2B1D48425C78}:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Babylon5
Oct 11, 2015NETGEAR Employee Retired
- 6gkidsOct 11, 2015Aspirant
Oh I guess I'm not done. I am still having trouble setting up the gateway. I land up with two router network names. The original which the pc stays connected to, but the network map has just a gateway between the pc and internet (an ethernet connection). I get into the netgear gateway fine with the changed information, however, on the page that shows trusted devices, my pc is the only one on it, and it has the name of a generic ethernet switch4(?) I had to readd the printer too, which I did on the pc in add a printer. It couldn't download one, but I saw it in the map connected to the original netgear name. I'm sitting here trying to figure out just what is going on. I hate to call someone there, it's harder to explain than to write. Any more questions, ask me, I probably left something out. Also I haven't been able to get into the routher interface safely very often. It did allow me to get in with a safe connection this last time. I just don't know how to get the connection understood with my pc, printer, and the wireless gateway. When I change the ssid and passphrase, I also have to go configure my mac laptop, which is fine and is all hooked up to new router name. Its interface is 802.11. I added my printer's mac address in as well and it has an interface as well of 802.11. The only generic is my pc, and the printer doesn't show on the map at all.
I probably have you totally confused. I apologize, it's so depressing.
Thanks
- Babylon5Oct 18, 2015NETGEAR Employee Retired
Sorry I haven't replied sooner, do you still have issues?
