trinaw518
Mar 20, 2016Follower
Configure netgear to my smart tv
I recently bought a samsung link stick to connect my smart tv to the internet wirelessly. I was told my the Netgear support that I will need to configure my netgear router to connect to my television...
HiThere22
Mar 20, 2016Star
Go ahead and try this Samsung is know for having issues with their security mode even though they say they do Support wpa2 alot of times they dont. Go ahead and try connecting with WPA TKIP and see if it connects be aware TKIP will drop your wifi speeds but we will use it as a test. If it does not connect with WPA-TKIP go ahead and try an open network and see if it connects if not I would set a static IP then place your TV into a DMZ mode then reset the rotuer then try the tv again however you will have to turn the TV off and on again.
