GlennLe
Sep 11, 2023Aspirant
Configure Nighthawk CM2050V with GS305EP switch and 3 WAX610 wireless access points
I plan on replacing my rented Xfinity cable modem with a Nighthawk CM2050V. Since the CM2050V doesn't have a wifi router built in, do I need to purchase a wifi router or a regular router to work with...
Sep 11, 2023Guru - Experienced User
Yes.
Something that is supporitng of yoru ISP service speed. If you have 1Gb ISP service speed, any RAX series router will work good. IF you have more than 1Gb ISP service speed which the CM series modem supports up to 2.5Gb, then you might consider a router that has support for those speeds on the WAN and LAN side if you have the need. RAXE500 or RS700 when it comes out.
GlennLe
FURRYe38, Thanks for the quick response. So do I still need a WiFi router between the modem and switch for the Wireless Access Points to work?
- FURRYe38Sep 11, 2023Guru - Experienced User
Yes, something router. You don't have to have a wireless router combo, a wired only router will work.
NG used to have router only models. I think they moved to firewall appliaces that would work for you as well if you don't want a wireless combo unit. Only other wired only router I know of is the Ubiquity Edge Router X mode.
