sactoerikm
Sep 16, 2024Follower
Configuring Netgear CM1000v2 to Ethernet with Google nest router
Hi all: I recently upgraded my internet speed to 1.2GB. I have a Google Nest for the router and a Netgear CM 1000v2 for the modem. I also have a five-port ethernet switch. When I use Google Ne...
Sep 17, 2024Guru - Experienced User
IF you want to see speeds past 1Gb, then you'll need both a modem AND wifi router that has WAN and LAN ports that support 2.5Gb or higher.
sactoerikm wrote:
Hi all:
I recently upgraded my internet speed to 1.2GB. I have a Google Nest for the router and a Netgear CM 1000v2 for the modem. I also have a five-port ethernet switch. When I use Google Nest and Netgear CM 1000v2 modem, the speed is reduced from 940mbps to 700mbps vs being connected to an ethernet. I am trying to determine what is the best "fix" (if at all) for this issue. Do I need to upgrade my Netgear modem (ie. Netgear Nighthawk) to have more than one port so I can connect directly to the ethernet and a second port connected to the Google Nest router? Would upgrading to Googe Nest Pro resolve this issue? Or is there even a solution? Any help would be greatly appreciated.
Erik
