Retired_Member
Aug 10, 2022confused password problems CAX80
Greetings, Recently I changed my Netgear password, but when I use 192.168.1.1 it will only accept my old password although when I check 192.168.1.1 "wireless settings" the passwords are the new passw...
- Aug 10, 2022
So your changing the wifi SSID password?
Have you set the wifi devices them selves to forget the wifi network then reboot and try to re-connect to the modems wifi?
Aug 10, 2022Guru - Experienced User
