Retired_Member
Aug 10, 2022confused password problems CAX80
Greetings, Recently I changed my Netgear password, but when I use 192.168.1.1 it will only accept my old password although when I check 192.168.1.1 "wireless settings" the passwords are the new passw...
- Aug 10, 2022
So your changing the wifi SSID password?
Have you set the wifi devices them selves to forget the wifi network then reboot and try to re-connect to the modems wifi?
Retired_Member
Aug 11, 2022Greetings michaelkenward,
I was unaware there are multiple passwords, The one password allowing access to 192.168.1.1's (GUI) and if I understand you correctly there can be two more passwords within the GUI associated with the 2.4 and 5GHz bands. Is it necessary that the 2.4 and 5GHz bands be same or different in relation to one another?
Thanks, Louf
michaelkenward
Aug 11, 2022Guru - Experienced User
Not so much "within the GUI" as things that you can use the GUI to change.
Your choice. Unless you have a reason to have separate SSIDs, it is often easier, and Netgear recommends it, that you use the same SSID for 2.4 GHz and 5 GHz.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Check the section in the manual Specify Basic WiFi Settings.
There may also be some helpful videos on what to do.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
- Retired_MemberAug 12, 2022
michaelkenward,
I downloaded the manual for the CAX80 and will check it out.
Thank you, Louf
