SamWolfe
Apr 30, 2021Follower
Connect c7000v2 to c7800
Is it possible to Connect a c7000v2 to a C7800.
I'm considering upgrading my modem/router to the C7800, and I'm wondering if I can connect the C7000v2 to it to provide additional Wi-Fi support on the other side of my large house.
I currently have the R7000 connected to the C7000v2 the other side of the house. The R7000 would be replaced by the C7000v2.
Is it possible? If so, how?
1 Reply
The R7000 is going to perform better than the C7000.
the combo devices tend to have slightly lesser performance than the router only units because they aren't having to share resources between the router and the modem.
Can you connect it to the C7800? There is a way. this guide is for the C6300 but should work still for the c7000.
Can I use a C6300 cable modem without cable intern... - NETGEAR Communities
