jordan23jaguar
Jan 01, 2023Aspirant
Connect google mesh to nighthawk 5G
I have my Nighthawk C7800 in bridge mode and I need to connect my Google nest mesh pods to the 5G. How do I connect to the 5G
- Jan 02, 2023I have it in bridge mode and it's working because I have it plugged directly into the router. I got rid of the Google mesh and I have replaced it with the Orbi and the Orbi passes by the 2.4 and connects to the 5G.
Jan 02, 2023Guru - Experienced User
1. The C7800 (if thats what you have) doesn't have a bridge mode. It has a modem only mode and a modem/router mode.
https://kb.netgear.com/27191/How-to-set-the-cable-modem-router-to-be-on-modem-only
2. the google mesh setups need their own router to run off. they don't have a wisp mode to connect to another routers wifi and act as repeaters. Only their own.
3. so I'm not sure exactly what you're trying to do here.
Do you have the C7800 setup in modem only mode? If so, simple connect the google mesh router to the c7800 in port 1 and then setup the google mesh's satellites. Or maybe a better description of what you're attempting might help
michaelkenward
Yet another example of how "bridge mode" is confusing and best avoided.
- jordan23jaguarJan 02, 2023AspirantI have it in bridge mode and it's working because I have it plugged directly into the router. I got rid of the Google mesh and I have replaced it with the Orbi and the Orbi passes by the 2.4 and connects to the 5G.
- michaelkenwardJan 02, 2023Guru - Experienced User
jordan23jaguar wrote:
I have it in bridge mode ....We still don't know what you have in "bridge mode".
I have replaced it with the Orbi and the Orbi passes by the 2.4 and connects to the 5G.Good for you, although it doesn't make much sense.
