msearhart
Aug 31, 2020Tutor
connect to mesh wifi system
Can i connect a mesh wifi system (possibly orbi or possibly another brand) to the C6300 modem/router? Or do i need just a stand alone modem?
Aug 31, 2020Guru - Experienced User
You can connect it to a modem/router combo device. I have.
options:
1. leave the modem/router in router mode. place the mesh system in AP (access point) mode. Just make sure to seperate out the wireless channels on the combo device from the mesh system so they don't interfere. I'd also name them different.
2. You can disable the router portion of the combo device if you want to run the mesh system in router mode. downside? it disables the wireless/routing functions. Leaves it only a modem in function.
msearhart
Sep 01, 2020Tutor
Thank you - i would think i'd want to go with #2 and disable the wifi on the c6300 as I wouldn't need it with the mesh routers? I decided to go with the Eero Pro instead of the Orbi as I liked the size of Eero vs the large Orbi hubs.
- plemansSep 01, 2020Guru - Experienced User
its pretty simply to disable the router portion.
log into the router through the browser, select ADVANCED > Administration > Router Mode. Then select no under the router option.
You can find the manual here: https://www.netgear.com/support/product/C6300.aspx
