msearhart
Aug 31, 2020Tutor
connect to mesh wifi system
Can i connect a mesh wifi system (possibly orbi or possibly another brand) to the C6300 modem/router? Or do i need just a stand alone modem?
Sep 01, 2020Guru - Experienced User
its pretty simply to disable the router portion.
log into the router through the browser, select ADVANCED > Administration > Router Mode. Then select no under the router option.
You can find the manual here: https://www.netgear.com/support/product/C6300.aspx
