Chris156
Mar 18, 2023Aspirant
Connect to NAS SSK SSM F100
Bottom Line Up Front: I am trying to browse pictures and watch video through the Netgear Router DLNA Server with content from my NAS on my Smart TV. All of this "used to work" Now, nothing is worki...
Mar 18, 2023Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
Something to contact the mfr of the NAS as well regarding there product...
- Chris156Mar 18, 2023Aspirant
Hi. Thanks for the suggestions.
I probably should have added that I have attempted various flavors of Reset/Restart systems and components.
I was probably less than clear that although the NAS (SSK SSM F-100) advertises itself as DLNA and UPnP capable; it isn't really capable of doing so.You "can" cast a (singular) video or a (singular) picture by activating the DLNA feature on the SSKCloud cell phone app. This is by far way too tedious to be useful.
I was hoping that someone knew of a way to get the Netgear Router (and thereby the reasyShare DLNA Server) to see the contents of the NAS.
I am thinking that this is not going to be feasible without dumping drive contents to a USB stick.
Small note: I have found that the Netgear Router does not interface very well with 2 different 2TB USB HDD devices that I own.
- FURRYe38Mar 18, 2023Guru - Experienced User
Ya thats not possible. Anything on NAS is considered a external source. The ReadyNAS and Share and such require the USB attached storage device.
I would inquire about the NAS having it's own sharing abilities and such with the Mfr. May have something there.
- Chris156Mar 18, 2023AspirantThank you.
Even negative confirmation is better than beating my head against a wall. Thanks!
