gomespablo
Jul 20, 2019Follower
Connect to Netgear CG3700 with "router" turned to Off?
My ISP provided me with a Netgear rounter with coax input. The routers wifi has been really **bleep**ty and not working properly so I get a new router and are now using the Netgear only as a modem be...
michaelkenward
Jul 21, 2019Guru - Experienced User
What is this CG3700? I can't find it in the Netgear system?
Could it be the C3700 cable modem/router? Or is it something that Netgear hand rolled for your ISP?
There is a manual for the C3700 somewhere at the end of this link:
>>>> C3700 | Product | Support | NETGEAR <<<<
It is probably much the same for your device.
gomespablo wrote:
But I forgot to first disable wifi so there's still two wifi's broadcasted from the Netgear router.
If it is the C3700, then there is a switch on the top that turns off the wifi. See the bit in the manual LED and button descriptions. Easily missed because it combines a switch and an indicator.
gomespablo wrote:
How do I connect (enter the menus/settings) to the "thing" now that it's not really a router anymore?
As the thing is still broadcasting wifi, you could see if you can track down the IP address of the wifi from the modem/router, then aim a browser at that IP address. If you are lucky it will throw you into the browser graphical user interface (GUI) for the modem/router.
You could use the Network Map in the desktop genie to reveal the IP address.
Is the ISP charging rent for this modem/router? If so, I'd be tempted to return it and buy a "modem only" cable modem.
- schumakuJul 22, 2019Guru - Experienced UserGC3700 is a Netgear OEM device - contact your ISP for any support or assistance.
- antinodeJul 23, 2019Guru
> [...] and the usual 192... address but couldn't.
What, exactly, does "the usual 192... address" mean to you? Did you
try "192.168.100.1" (the default address to access a DOCSIS modem)?
