emphasison
Jun 15, 2021Aspirant
Connected: No internet
I have a C6300 with AC1750. On several different devices when I attempt to sign in to wi-fi I receive message stating that device is connected but there is no internet. I use this router to use w...
Jun 15, 2021Guru - Experienced User
1. Is it only wireless devices with issues? Or do both wired and wireless have issues?
2. do you have a screen snip of the cable connections page and the event logs?
emphasison
Only wireless
I have no logs
Thanks
- plemansJun 15, 2021Guru - Experienced User
So only wireless have issues? just confirming.
Because if the wired devices all work fine, then your signal should be good.
And you do have logs and a singal connections page. They're built in.
- emphasisonJun 15, 2021Aspirant
And if I should require these logs, where and how would I obtain them?
