emphasison
Jun 15, 2021Aspirant
Connected: No internet
I have a C6300 with AC1750. On several different devices when I attempt to sign in to wi-fi I receive message stating that device is connected but there is no internet. I use this router to use w...
emphasison
Only wireless
I have no logs
Thanks
Jun 15, 2021Guru - Experienced User
So only wireless have issues? just confirming.
Because if the wired devices all work fine, then your signal should be good.
And you do have logs and a singal connections page. They're built in.
- emphasisonJun 15, 2021Aspirant
And if I should require these logs, where and how would I obtain them?
- plemansJun 15, 2021Guru - Experienced User
Thanks for the links
However when I attempt https://192.168.100.1/ infirebird or chrome receive message "unable to connect"
