Nigelnet1
Jan 19, 2021Follower
Connecting 2 ethernet PC's and one eero wifi hub to Netgear CM1200
Are there any issues with connecting 2 PCs to Ethernet ports and a EERO wifi base unit to a third Ethernet port with the CM1200 Cable Modem?
> Modem?"Ethernet ports" _where_? On the CM1200? One potential problem
("issue"?) might be that it probably wouldn't work.https://community.netgear.com/t5/x/x/m-p/1770096
Note: "a EERO wifi base unit" is not a very detailed description of
anything. "base unit" tells me approximately nothing. Has it a model
number?
