tcac
Aug 21, 2021Follower
Connecting a Nighthawk MR60 to a Nighthawk AC1900 cable modem
I connected a Nighthawk MR60 mesh router to my cable modem router and it autoconfigured the local network IP as 172.16.0.1, whereas my modem router has a network IP of 192.168.0.1. This creates 2 LAN...
Aug 21, 2021Guru - Experienced User
You're in a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
options? (only use 1)
1. put the c7000 modem only mode. Disable its router features.
2. put the MR60's ip address into the C7000's DMZ.
3. Put the MR60 in access point mode. (this would be the route I'd use if i had that setup).
