brendaknoll
Jul 23, 2020Follower
connecting a switch
Since this onlyhas one port, do I connect a switch to the modem? or do I let the modem find the wireless router wirelessly, and then conect the switch to the rouoter?
Jul 23, 2020Guru - Experienced User
What device are you talking about? you didn't put any models or anything for us to help with. so all we can give you is generals.
If its a modem only, it needs to go:
modem------->router------->switch
if its a modem/router combo device, then you can put a switch directly connected.
you can go to netgear.com/support/ and type in your model. it'll take you to install guides, manuals, etc.
