HappilyEverWhee
Apr 23, 2024Aspirant
Connecting CM1200
I purchased the Nighthawk CM1200 and the instructions say to connect the coax cable, however my internet comes in via Ethernet portal (AltaFiber/Cincinnati Bell Fioptics). Did I buy the wrong model? I...
- Apr 23, 2024
Yes. The CM series modems is for Cable ISPs. Wont work on Fiber ISPs.
You need a Wifi router system to connect to the ethernet wall jack or the Fiber ONT device that has a ethernet port on it.
HappilyEverWhee
Any recommendations for the right modem? I have a TPlink deco mesh system but am told I need a modem to connect. Everything I find online is for cable modems
Apr 24, 2024Guru - Experienced User
If your ISP uses Fiber services, then you'll need to contact them and ask about an ONT (Optical Network Terminal) unit for use with there services that you can connect your router system too.
Good Luck.
