JRDTX's avatar
JRDTX
Connecting more than two devices to LAN ports and none can see Internet
If I connect another router to my Netgear and use that other router by connecting four or five devices to it, they all can see the internet and work just fine. But if I remove that other router and c...
  • JRDTX's avatar
    JRDTX
    Sep 10, 2015
    Everything is working fine. Note, please, that the Netgear modem/router has always worked fine - the problem was with the flaky DNS server addresses provided by Comcst.
