batman55
Oct 01, 2020Aspirant
Connecting other routers to C7800
Can I connect another router to this device? I want to run it from another room.
- Oct 01, 2020
You can connect another router to it, just make sure that your have the 2nd router in access point mode or you'll have a double nat issue.
Oct 01, 2020Guru - Experienced User
- batman55Oct 01, 2020Aspirant
Thanks for your input. Very much appreciate it. I'm going to have to use a very long cable. Should I specify highspeed for that cable. I see there are cat8 cables. Would that be a good choice?
