batman55
Oct 01, 2020Aspirant
Connecting other routers to C7800
Can I connect another router to this device? I want to run it from another room.
- Oct 01, 2020
You can connect another router to it, just make sure that your have the 2nd router in access point mode or you'll have a double nat issue.
Oct 01, 2020Guru - Experienced User
Or you can put the C series modem in to modem only mode and then connect a external router in router mode. No double NAT here.
batman55 wrote:Can I connect another router to this device? I want to run it from another room.
