Dondirdev
May 18, 2020Aspirant
Connecting ROKU device to Comcast TV...Modem model # is CM500V
Trying to connect ROKU device to Comcast cable TV (Phillips Smart TV, about 10 years old). Does ROKU need to be listed with NetGear Modem or Router? Tried connecting device with HDMI cable but with n...
- May 20, 2020
> [...] Modem model # is CM500V
Ok.
> [...] Does ROKU need to be listed with NetGear Modem or Router? [...]
Which Roku model? Did you intend to connect it wirelessly (to
whatever)? What is your (unspecified) "Router"?Generally, the only thing which you'd connect to your modem would be
your router (WAN/Internet port). Any client device (like, say, a Roku
box) would be connected to the router (LAN Ethernet port or wireless
LAN).> [...] Tried connecting device with HDMI cable but with no success
> [...]"connecting device with HDMI cable" to the TV? If you can't get a
video display from the thing on your TV, then a network connection would
seem to be the least of your problems.
antinode
May 20, 2020Guru
Ok.
LAN).
