moonoven
Nov 01, 2021Follower
Connecting to a Solaredge InverterC7000 v2
I have an inverter that is part of roof mounted solar panel system. The inverter has a communication card that allows monitoring of the inverter in real time through a web browser. I had it connected...
Nov 04, 2021Guru - Experienced User
Do other wired devices connect to the back of the modem and work?
Be sure that the devices is using a auto obtain IP addressing configuration, not a static IP.
Be sure your LAN cable between this devices and the modem is in good working condition. CAT6 is recommended.
