tillahoffmann
Mar 05, 2022Initiate
Connecting to AC1750 WiFi Cable Modem Router C6300
I would like to connect to my AC1750 WiFi Cable Modem Router C6300 by WiFi but cannot see the SSID that's written on the product label (NETGEAR04) in the list of available networks. The indicator lig...
- Mar 06, 2022
Glad it worked! Even if I didn't do much ;)
If you mark it solved, it keeps others from trying to fix an already fixed issue
Mar 06, 2022Guru - Experienced User
A couple things.
1. Your device isn't getting connected to the isp or both the upstream/downstream lights would be working.
2. even if they aren't working, you should still be able to connect to the router. You might need to borrow a wired laptop or purchase an ethernet--->usb adapter so you can connect something hardwired to the router. Maybe your label is incorrect with the ssid name or it isn't properly resetting. So you'll need to log into the device to check it.
