oldgeeze
Dec 03, 2018Aspirant
Connecting to Arris SB8200 modem. Want to have both hardwire and wifi connected.
Hello. I first purchased a CM1000 modem but had problems with it. Then I purchased a Arris SB8200 3.1docsis modem with two ethernet ports because I wanted to use one port to connect to my Nighthawk R...
antinode
Dec 03, 2018Guru
> [...] Can I use the Netgear GS308 to connect to the Arris modem [...]
No. If your ISP gives you only one (WAN) IP address, then you can
connect only one (addressable) device to the modem. Generally, that's
why NAT routers exist -- to allow multiple devices share that one (WAN)
IP address. A GS308 is a switch, and, as such, it lets you connect
multiple devices, but it does nothing to get them their own IP adresses.
> [...] I want my desktop to be hardwired thru the GS308 to the modem.
> But I want my other computers to be on wireless.
What you should want is to connect a router to the modem, and then to
connect all your other devices to the router (by wire or wirelessly).
