McFarmer's avatar
McFarmer
connecting to IP Address
I am unable to connect to my IP address (192.168.0.1) but do have access to the internet.  System has been restored to factory conditions after I recently moved.  Had internet turned on today by Spec...
  • vkdelta's avatar
    vkdelta
    Jul 08, 2018
    your ISP has forced BRIDGE MODE on your device.  Please go to 192.168.100.1 and change it back to router mode.
    If that does not work, factory reset the device and Call the Spectrum folks to REMOVE NO-WIFI CODE from your account. They are most likely doing to force you to rent their $4.99/month WIFI router.
